1 - 20 of 21 Posts
Does anyone with a tymar remember what they payed fo it? I am thinking about getting one. I know they are about 115 for the old style but don't know if they are they same for the super duties.
Ted
The newer style are a few bucks more because you have to purchase a different battery tray, as you lose the factory tray when you remove the airbox. It all comes with the kit. Give Dale a call, he will give you MORE than enough info to help with your decisions.
· Banned
I talked to Dale a month or so ago and I think it was around 175. Don't quote me on it but I think it is in the ballpark.
Scott
Get a Napa 6637, $40
22 degree piece of 4" exhaust, $25
4" Rubber coupler, mu buddy had that already but maybe $15 at the most and you are set for $80 total.
I got
napa 6637 $35.00
lowes 3" coupler $1.29
clamp from napa $1.00
and it works and seals great!
Cheaper yet:
Napa 6637 $40
3" long piece of 4" OD exhaust pipe $10
4" hose clamp $7
Remove your air box, trim battery tray with a dremmel tool and tuck filter in where the air box used to be. Zip tie air temperature sensor out of the way. Loosen and turn the rubber "S" hose coming from the CCV about 20% forward and retighten, insert pipe into the air filter and put hose clamp on filter end and tighten. Put other end into the stock rubber hose and tighten down hose clamp. Done. 1/2 hour and less then $60. /ubbthreads/images/graemlins/grin.gif
Would anyone see any problem of me installing a homeade tymar intake and still using factory exhaust and no tuner yet.
Thanks,
Cris
No problem what so ever! I am chipped but still running stock exhaust with the homemade "tymar" type set up.
My truck is a 2002. Would I still need to do some battery tray trimming when installing a homade tymar?
One more question.
Is there any damage that could be done running this type of setup without a wicked wheel?
Cris
Highly reccomend you add the Wicked Wheel when you do the Tymar. The open air element will cause surge/stall even more than the closed factory box. (best part is it sounds alot better,too)
I think I'm going to do the Napa intake on my truck this weekend when I install my WW. But what do I do witht the little air reset bottle thing that is on the top of the airbox? Does anyone have a piccture off this custom intake just so I know what it should look like? Thanks
I'll be honest with you, my filter restriction guage has never moved in 120,000 miles. I have now purchased a dash mount (2-1/16in round gauge) water column gauge for my new filter restriction gauge. It's supposed to be + or - .01% accurate.
Cheaper yet:
Napa 6637 $40
4" hose clamp $7
What are you doing with your air temperaturs sensor? Not using it? That cant be good.. /ubbthreads/images/graemlins/shrug.gif
Just move it out of the way, Don't disconnect it.
Look at the pics in my sig for an idea of what it looks like.
What is that big fuel regulator looking thing on top of your motor? /ubbthreads/images/graemlins/smokin.gif You have a link were is was discussed?
1 - 20 of 21 Posts
