Ok I have what appears to be a small? fuel leak somewhere on top of the engine? I recently had to replace the lift pump and in doing so I also installed new fuel lines, I have gone back in and double checked to make sure all nuts/bolts, etc are tight. There is fuel that seems to be pooling under the filter houseing but it is also wet back towards the pump, I have cleaned it with simple green and washed it off and then let it run some but can not find the source any ideas on where to look, thanks
Roy /ubbthreads/images/graemlins/cool.gif
