I went through all of the external electrical checks that I could do without the ability to excercise the shift solenoids via the PCM. I could not find anything at fault.
I put it back together and it shifts like new. Now I cannot break it again. It appears to have been some bad connection that I mended at least for the moment by disconnecting and reconnecting the various transmission harness connectors for my tests.
It worries me that it will happen again when I am far from home.
If anyone has had a similar experience I would appreciate hearing about it.
Thanks,
Paolo
ORIGINAL POST
I have shifting from 1 to 1 lockup to 2 to 2 lockup but nothing more. I retrieved PO782 fault code and I will do a thorough electrical wiring and connector check this weekend. It seems from examining the shift solenoid A and B truth tables that SSA is "on" all the time. I am limited at checking PCM output without breakout boxes.
The main question is for those who have experience with addressing PO782 fault code of no 2 to 3 shift.
HAVE YOU FOUND A SINGLE MOST COMMON FAILURE IN REPAIRING THIS PROBLEM?
Thanks, Paolo
Thanks,
Paolo
ORIGINAL POST
Thanks, Paolo
