1 - 13 of 13 Posts
OK now I have the factory installed upfitter switches. How do I get the 12v. from each of the 4 switches to use for external add-ons like additional lights, electric fuel pump, inverter? In other words, where do we hook up to? Realize the 4 fuses are installed and ready for use. Noticed 4 rubber tipped colored wires on driver's side just under hood taped to a wire loom. Is this the 4 switches output? Dealer no help. Owner's manual no help. After a few years on this great site I know the experts are here. We could call it "Upfitter Switches for Dummies". Thanks in advance and support our troops.
Thanks for the info however the 2008's dash is redesigned and the '05-'06 pictures and location are different. My old '05 was easy as the pictures show. Just butt connect from switch wire to one of 4 color wires that go thru firewall and presto. Found the 4 wires underhood. Just don't know how/where to hook up switches.
The outputs from the switches are under the dash on the drivers side (near the parking brake). They are very close to the ends of the 4 customer pass thru wires (the ones you saw under the hood), so you could connect the switch wires to those, and get the outputs in the engine bay.
Great response and to the point. Looked under dash near parking brake and found the 4 rubber tipped wires from the upper loom and were labeled Aux 1, 2, 3, and 4. Aux 1 and 2 were heavier wires and Aux 3 and 4 were the smaller wires. I take it these are hot when the corresponding switch is activated (up). Now the loom below this has about 18 rubber tipped small wires. Now if I can find the 4 that pass thru the firewall and taped to a loom I think all might be what I wanted in the 1st place. Just butt splice 1 of the hot Aux wires to the right thru firewall wire and presto (12v is available for whatever add-on we need). Why is nothing easy for the average buyer? Thanks much. Now to figure out the clor code. Excellent help!!!
2018 Ford F-150 3.0L Powerstroke, King Ranch, FX4
Pull the panel directly to the rear. There are a total of 7 clips to pull out. 3 on each side and 1 in the bottom middle. Pull from the bottom corners first.
Discussion Starter · #9 ·
2002ex-Getrdun-ckesdad Thanks for the info. Printed the 4 page Upfitter Customer Access Wires info. Now to remove the panel and hunt wires. Guess the 7 SEIC (D), 4 Bridge Circuits (D), and the 4 General Pass-Thru wires are on the loom I counted about 18 stubbed. Somewhere recently a member posted info about a high idle hook-up to an upfitter switch. Would that be the Battery Charge Protect (BCPSW)? Thinking about hard wiring a 1500-2000w. inverter to a battery and could need extra charging while in use. Also, anyone with knowledge about the Clean Tach Out (CTO) and Vehicle Speed Out (VS_OUT) circuits? On wait list for the wiring diagrams book from Helm, Inc. Make a good deal on my 2005 book. Thanks again!
The battery charge switch idles up the engine based on battery condition. It varies according to charge. I am going to use the PTO switch myself because that gives you a constant idle speed of around 1200. And it will only work if if certain criteria are met with the truck stationary. I think it is foot off the brake, in park on an automatic or neutral on a manual, and parking brake set.
ckesdad -- Just something to keep in mind. The PTO circuit raises idle to a constant 1200 - 1250 rpm, but the torque converter is locked. The BCP circuit raises idle to 1250 - 2400 rpm, depending on the battery charge state, without locking the torque converter. I use the BCP circuit and rarely see my idle over 1250 rpm. To use either circuit, the emergency brake has to be on and the transmission selector in Park.
HTH.
Well, we have tried to cover this ground several times...i thought that the BCP was right to use and others said the PTO was best. I have heard that the torque converter is not an issue, now I feel like you are saying it is. I think I am just becoming more confused.
Any help appreciated.
ckesdad -- Not a problem, just something for you to be aware of. The BCP circuit is the one I use regularly (for fueling from my service tank). I did not want the torque converter locked while I was high idling for furling because the extra engine drag just wastes more fuel. As there is little to no load on the transmission or engine the way I use the BCP circuit, there is no need for the torque converter to be locked. Hope this clears it up.
1 - 13 of 13 Posts
