Vendor
Are you looking for the best way to enjoy cool air flowing through your truck windows, even in bad weather? Or do you want to protect the hood from insects, stones, sediment, and other debris? Than Tough Guard has got you covered. This brand offers top-quality FormFit Side Visors and Hood Protectors, designed with aggressively styled “bolt-on” look.
If you value superior protection, clean styling, and easy installation, these products would be your best bet. Being road-tested and developed to eliminate unwanted noise and vibration, they are easy to install with no cutting or drilling required. Even if your truck doesn’t have fender flares, Tough Guard deflectors will perfectly complement it.
Tough Guard® - Tape-On FormFit Side Visors
Features:
  • Made from high impact ABS co-extruded with an acrylic top layer for a superior appearance and durable finish
  • Complement your Tough FormFit Guard with matching Tough FormFit Visors
  • OEM Quality look and feel
  • Won't chalk, fade or breakdown over time
  • Allows you to drive with your window open while offering protection from the elements
  • Increased air circulation
  • Each application is precision-fit to your specific vehicle
  • No cutting or modifications required before installation
  • Installation time in under 15 minutes
  • Attaches via 3M Automotive Grade Adhesive
Tough Guard® - Black FormFit Hood Protectors
Features:
  • Durable ABS with acrylic top coat has an OEM quality look and feel
  • Matches OEM and aftermarket fender flares and other components
  • Installs with 3M Automotive tape, patented mounting clips and stainless steel fasteners
  • OEM quality design rests on the mounting hardware
  • No contact between the deflector and the hood - no risk of paint wear
View the full list of Tough Guards Products for your Ford Tough Guard™ | Hood Protectors & Automotive Accessories — CARiD.com
Customize the looks of your Ford with Tough Guard Products from CARiD!​
