21 - 22 of 22 Posts
FYI do not put any aftermarket wheel in a garret 38r.
Unless you get it balanced 400+ dollars it will die in 10-15k miles. This has happened to a lot of people.
For 350-400hp you only neee 160/0 or 160/30
A healthy stock hpop works as does a healthy stock fuel system.
I would do a modified valve body and larger cooler if your an auto at a minimum as wel.
Thanks for the info. I am thinking Full Force on the injectors. I will try and do as much work as I can myself. I want to keep this truck as long as I can.
21 - 22 of 22 Posts
