Under another post (Turbo going south), I thought that my turbo was on its way out because when I hit 25 lbs of boost, I started hearing a shrill noise. As I pulled my trailer up the mountain passes, a couple of times it hit 30lbs when it downshifted - the noise got louder (I immediately shut off the cruise and got out of it).
I pulled the intake tube, got a hold of the wheel/shaft and could not get any movement in/out or side to side. Does that mean the turbo is fine?
I tightened all the boots on the cooler hoses to make sure that I am not getting a leak. There was a little oil near one of the boots, possibly a bit loose.
I did notice soot on the firewall by the uppipes. Can the uppipes make a shrill noise as the boost in the system is pushed up? I know I should replace them, but I'm just trying to determine what the noise was and where it came from.
Thanks,
MM
Thanks,
MM
