I have now processed about 120 gallons of oil through my system. I keep a data sheet on each batch. Here are the numbers from those batches. They help me decide if my processing is uniform and consistent. They also give me a starting place if I decide that something needs to be changed.
Date Viscosity in Zane seconds Specific Gravity Temp F
7/29/2011 - - - - - - 35 - - - - - - - - - - - 0.843 - - - 80
8/18/2011 - - - - - - 42 - - - - - - - - - - - 0.844 - - - 65
9/1/2011 - - - - - - 43 - - - - - - - - - - - 0.844 - - - 65
9/4/2011 - - - - - - 42 - - - - - - - - - - - 0.846 - - - -67
Batch 1 had several gallons of ATF in it so the viscosity was lighter indicating that a little less RUG might be needed. Batch 4 was obviosly a little heavier, perhaps a little gear oil in the mix indicating a little more RUG might be needed.
Viscosity was obviously affected by temperature. If I need to make changes as I observe how each batch burns, I have a starting place so I can maintain consistency and have a place to start trying to figure out problems. So far, I am pleased with the consistency I have observed.
Sorry for the mix in numbers, the system will not let me enter in columns.
