Other than increasing the idle speed and controlling after market lighting, what are some of the other uses you have found for the upfitter switches?
Passenger ejector seat. :lol:
I do like the idea of Axle Lockers though. :thup:
Those are called "passthrough" wires, there are four of them. The passthrough wires are just that, nothing more than a connection through the firewall. They are not connected to anything on either side, i.e. they are not connected to the upfitter switch connections unless you make those connections.I know that there are blunt connections for the upfitters under the dash on the drivers side. I noticed that by the master cylinder on the drivers side there is the same blunt connections. Are these the same? I can use these maybe instead of pulling wire through the firewall?
Thanks.
