Quick! Which "blunt" wire do I use!!! :wink2:I use #1 to activate the cones of silence when my wife gets in the truck!
is there a special compressor you have to use? and what version software do you have in your nav system? i have 4p and would love the opportunity to "share a newer version" with people. i have software to "make a backup" copy should it ever get scratched.Driving lights, High beams since I went with Projector style headlights and split the 4 bulbs to work anytime, MIRT, Compressor....mounting 4 more aftermarket switches for air horn, rear spot lights, lights under bed cover.....
is there a special compressor you have to use? and what version software do you have in your nav system? i have 4p and would love the opportunity to "share a newer version" with people. i have software to "make a backup" copy should it ever get scratched.and what is a MIRT?
My '08 job 2 automatically goes into high idle after a couple of minutes. Is that a built-in feature or something that the dealer set up before I bought it? Is it necessary to have the high idle set up for a sooner kick-in than a couple of minutes?As you probably know, allowing your truck to idle at a "resting" idle RPM potentially allows fuel to pass into the crankcase and, thereby "making" oil. As you also know, there is a idle time indication available as part of the engine diagnostic readout. The high idle feature allows you to idle at a slightly higher RPM and reduce potential issues. I guess others use the high idle for PTO features?
