Thank you for your response. You have experience with this that I lack, at the same time, I am hesitant to use your dosage when I read other things such as what I'm pasting below. Hence, my confusion and hesitance.
According to the FDA, the "recommended minimum dose level [is] 6.0 mcg ivermectin per kilogram (2.72 mcg/lb) of body weight" for treatment of heartworms in dogs. This is the dosage in the FDA approved Heartgard.
For example, for a 40 lb dog, I calculate that as: 2.72 x 40 = 108 mcg or .108 mg. See:
http://www.fda.gov/cvm/FOI/730.htm
Dilute Ivomec (you want the 1% injectable Ivomec for cattle) one part Ivomec to 9 parts propylene glycol....then give the dog 1/10 of a cc per 10 lbs. of dog of this solution (a 40 lb. dog gets 4/10 of a cc.)
Simply add 0.3 ml’s of 1% Ivermectin injectable to one ounce of propylene glycol, making a 100 microgram/ml solution. Dose this at 0.1 ml per pound of body weight (10 micrograms per pound) once monthly."
Hopefully this can settle the debate.
I wanted to figure out exactly how much has my dog been getting by taking Heartgard because I have a Border Collie and an Australian Shepherd and was a little concerned about harming them.
Here is the breakdown.
Heartgard has 272 mcg or Ivermectin for the 50-100 dog dose
157 mcg for the 25-50lb dose and 68 mcg for the up top 25 lb dose.
I figured this out myself and then verified it with another persons formula for which the web site is.
http://www.convertit.com/board/view.asp?mode=viewtopic&topicID=749&forumID=1&catID=9
Here is the Formula- they base it on 2.73 which means that the Heartgard 51-100 lb dose is based on the 100 lb dog.
THE FORMULA
Ivomec Ivermectin has 10 mg or 10000 ug per cc. 6 ug per kg is 2.73 ug per pound. So multiply the dog's weight in pounds by 2.73 to get the micrograms needed, and divide that by 10000 for the number of cc's to give the dog.
So for a 100 lb dog.
100 x 2.73 = 273
273 divided by 10000 =.0273 ml or cc
thus your Hundred lb dog needs just about 1 quarter of a cc of ivermectin 1% solution per month.
I made a table to make it easy or you can just use the formula. I rounded the numbers.
10 lbs = .0027 cc or ml (call it .003)
20 lbs = .0055 cc or ml
30 lbs = .0082 cc or ml
40 lbs = .011 cc or ml
50 lbs = .013 cc or ml
60 lbs = .016 cc or ml
70 lbs = .020 cc or ml
80 lbs = .022 cc or ml
90 lbs = .025 cc or ml
100 lbs = .027 cc or ml
The precise dosage of Ivomec 1% for dogs is 0.0027 cc or ml per 10 pounds. This based on the concentration in Heartgard for dogs. I verified the concentration and dilution with a vet, a pharmacist and a chemist.
