Thanks all for being part of this amazing info source. I've got my first 7.3 PS 2002 in an E350 van. Got reman eng from Ford in and its got only 75K on it now. Wondering what that "plug" is on the passengers side valve cover on the top. I keep finding the whole VC caked in oil, I clean it, and it seems to be originating from there and my turbo boot. If this just some type of vent cap? Don't know if cleaning it out or replacing it to mitigate leaking is the answer as it never did this before. Been looking everywhere and can't put a name to it so don't know what to order or how to find it in the forum.
Also, suddenly van stopped cold starting. Gotta keep it heated anywhere below 50. Only white smoke at first start up. Runs fine thereafter, but smells a little "rich". I found a wiring harness adapter that allows checking resistance at each GP by plugging it right into the VC. Its got white ports for the GP's and also got some colored wire "ports" as well. Would these be for checking resistance on Injectors? Didn't come with directions. I'm getting the "click" when I turn key do presuming PCM is getting correct info from EOT sensor, tested relay at 12.7v . Any other mid stream things I can look at?
