First off, I would like to say that I have NEVER been this dissapointed in a Ford vehicle in my life. I have an 08 F550 4x4 with a wrecker body on it. We have changed the oil every 4500-5500 miles (due to using it for towing), and we have done regular transmission services, and have changed the fuel filters.
I have done a search here on the site, and it could possibly be the "EGR Cooler? or even a problem with one of the cylinder heads. I'm going to explain it as good as I can, and see what you guys might think.
To start off, this truck was bought new in April of 08 and now has 58,??? miles on it. This truck has been in the dealership more than we have actually been able to use it.
*****Build Date 01/08*****
1st bad radiator was at 14,000 miles
2nd bad radiator was about 20,000 - 24,000 miles
3rd bad radiator was about 40,000 miles
After the last radiator was replaced we have had a HUGE problem with coolant going into the oil. We explained to the dealership about what was happening, and they stated they heard about the problem and were going to order a few parts and they would fix it. They told us to continue to add coolant and use the truck until the parts came in. About a week later we dropped off the truck for 3 days, and they said they they "pressure tested" everything but found no problems and just replaced the coolant tank and said it would be fine?! They didn't even drain the more than 6 gallons of oil/coolant out of the motor. My biggest question is... What would a bad coolant tank have to do with coolant getting into the oil??? If the tank was "bad" wouldn't it leak onto the ground instead? So last Sunday I drained all 6+ gallons out, changed the filter and filled in back up with 15 new quarts of oil. Just 5 days later the coolant level is down over 2 inches and the oil is way over full again. This dealership keeps telling us that there is no problem with it?? I'm taking the truck to a different dealer this week and see what they say about this issue. I'm mainly just trying to see if anyone has had the same issues with Ford and their dealerships??
I really appreciate any and all of your input :thumbsup:
