Hi - This is my first diesel truck and this vibration is driving me nuts.
It is a 2004 F-350 4X4 Lariat Crewcab 6.0L with 185K. It has new "E" rated tires on it and I have had them balanced and the rims checked by two different shops. Both shops have said the balance and tires are true. I replaced the steering knuckle on the passenger side and the U-Joint in the drive shaft. Both shops recommended that I get new shocks and front rotors.
You can feel the vibration at around 35 MPH and it gets worse as you increase the speed. The vibration is still there at all RPM's and if you put it in neutral at 55. The vibration appears to vibrate the entire truck and just at a loss as to what to look at next. Any and all suggestions would be greatly appreciated.
