1 - 8 of 8 Posts
I am pleased with the one i have for my 7.3.
They use an AFe filter as I understand it...and seem to be well made.
I am really having a hard time between the volant and the airaid. I think volant is what I want but I have an 05 but I do have a sensor thing in my box so will I be ok?
kk
I Bought a volant it never ran with it on. It sucked the fit is horrible my maf wouldnt even screw in tight to form a seal due to the holes for the screws not being flush. The lid would not seal due to holes not being equal in all 4 corners only 3 would screw down, The side scoop and the battery were fighting for the same space. Don't get me wrong I loved the volant for my f-body, but for my 05 F350 nevermind.
If u still want to try it I sell u mine cheap just part of the side scoop bottom cut so it would fit. Send me a PM.
I had a Volant on my 05. I took it off because I didn't feel comfortable being able to see through the filter. The newer ones may have a ProGaurd 7, but mine surely didn't. For the temp sensor, I simply put a rubber grommet around it, then taped the grommet with foam tape so that it would create a good seal. Then I just pressed it into the MAF hole, and it worked well. For added protection, I duct taped around it, but I still didn't like the filter. If you have an 05, and still want the intake, do what I did with the grommet and all. It definately did make things louder...
1 - 8 of 8 Posts
