I have been very fortunate and never had to replace an alternator on my 7.3 PSD’s.
I always keep an eye on my ScanGauge-II and the Voltage tops out at 14.2.
The last few mornings it has climbed to 14.3 and now 14.4 with a brief peak of 14.5 a few minutes after the GPs stop cycling. I want to start preparing for a replacement.
Are any of you just replacing the integrated Voltage Regulator or the entire Alternator?
Where and what model are you replacing with? Thanks
I recently replaced the original 02 110 Amp small case 6G that came with my truck new. No electrical symptoms bearing noise. I investigated some of the premium upgrade rebuilds and agree that many would be better than new and their price shows it. Their short warranties dont really fit in with their great better than new testimonials. So, I bought a new LARGE case 135 AMP 6G for a 6.0 PSD from O'Reilly for 284, 5 buck core charge, lifetime warranty and it fit my 7.3 without any bracket mods and hooked up in 15 minutes. Lifetime warranty, national chain, I travel thats important, not a skimpy rebuilder 1 year warranty. I bought a rebuild kit and rebuilt my original 110 AMP alternator myself. New rectifier bridge, rotor slip ring, bearings and voltage regulator. Had it load tested and it is good, so I have a spare. Rebuild difficulty, 2 on a scale of 10. Not nearly as difficult as many common PSD maintenance items. Only special tool one will need is a 200 Watt soldering gun, I gad a 300 so all good. There are only eight small solder on crimp connections to do, 10 minutes and easy to position.
The new O'Reilly Alternator works great, I have aprox 5K miles on it. If your alternator has 100k miles on it there is likely more happening than just voltage regulator, slip ring wear is likely. For less than 60 bucks one can just do a complete rebuild. Had I not needed an alternator right away for a job trip to Minnesota I could gave just rebuilt the original, I didnt have time to wait, had to go make a few bucks.
