voltage regulator problems
42K views 19 replies 10 participants last post by  cdude20
You will save yourself so many headaches by switching to the 3rd gen alternator. I got mine out a junkyard taurus that was crashed almost immediately after the alternator was replaced. Basically brand new for $25. Plus you have so much more amperage to play with when it comes to lighting and heavy electrical loads. I have had mine installed for almost 5 years now.
3G Alternator Install
You'll read in there he clocked the case differently. I didn't even have to do that. Or grind the pulley at all. Just swapped on the v-belt pulley (unfortunately still v-belt) and bolted it right in. A little bit of wiring, and it's in!
For reference I have an 89 7.3 N/A
