Greetings, I got a problem and wondering what I am looking at price wise.
Cold start fine.
Warm crank no start. Had this problem back in 06 and HPOP done under warranty. It is back again.
04 6.0 per Ford Service dept. needs:
$200 diag. - completed.
1200 tear down. - completed
HPOP
Injector Pressure Regulator?
Valve Cover Gasket from Air test.
Oil Change
CC DAC Switch Connector
They also say I need the BG Cooling and BG Induction Cleaning. However, I just had my AC serviced and access ports and Remove and Refill done.
They are quoting $5000 out the door. How crazy is that?
Thankfully, the Lord just found me a new job 2 months ago after not working for 10 years. So I can afford it...I guess.
Thanks.
Cold start fine.
HPOP
Oil Change
Thanks.
