Just a head's up. Many of you may know about this already, but I did a search and did not come up with anything.
The hood release cable can break, and make it a real chore to open the hood. The symnptoms are that it is real hard to pull the release, this is a sign that the cable is fraying on the inside.
My old truck (the 85) was not hard to pull at all. This truck, (the 84) has always been harder to pull then the 85 was. I thought it was harder because the latch was not adjusted right (or the bumpers that set the hood height). I kept messing with it, but it never got any better.
If your hood latch relase cable is hard to pull, you might consider buying a spare and replacing it now. I doubt you will have much luck lubricating the old one, since it has more to do with frayed cables then corrosion.
The new one from FORD, is $69.95 /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/blush.gif /ubbthreads/images/graemlins/eek.gif /ubbthreads/images/graemlins/tongue.gif
I found one on E-bay for 4.95
Just a heads up.
Just a heads up.
