I have a warning light on (picture of engine)one place in the owners book it says emmissions problem, in another place it says sevrvice engine soon. 3018 miles (06 f350) I assume the engine wants its oil changed. Not sure about the emmissions problem. Any thoughts.
Several good replies... my 1st thought is that you have "overfueled" it. Ford changed the programing in 05-06 to set a SEL if you fill up the filler neck, and the truck starts acting like its out of fuel when the low fuel light comes on.
If your truck has a total of 3,000 miles on the factory oil, you may want to change it out now, otherwise, 3,000 is a serious waste of money & natural resources. The manual says 7.5k for normal & 5k for severe / heavy towing. I've run Delo 400 CI-4(+) at 7.5k intervals w/out any problems for 50k miles now. Blackstone OAs at ever change. They still say "try 7,500 miles & sample again".
The 1st tank that I filled up I filled it to the top, 50 miles later CEL (682 miles) took to dealed, and it was an overfill code. Now I just wait till pump kicks off and add another gallon. No more problems.
