The gasket/rubber block between my solenoid and the turbo has gone bad causing a massive oil leak. Problem is I cant find a part number or a place poto buy it. Tried local dealer and no luck. Also, am I likely to find a Bigger, different problem once I fix this?
I assume you mean the the o-rings between the turbo and the EBPV. The waste gate solenoid does not have anything to do with oil.
The turbo sits on top of the EBPV and is sealed with a couple o rings. They can be bought locally at any Ford dealer or ordered online at Diesel O Rings.com
They also have instructions to help you out.
No, I was actually talking about the wastegate solenoid. After further investigation, I figured out the hpop hose sitting under that solenoid had split and was shooting oil on that screw making it look likely oil was coming from there. couldn't see the split until I got way in there and had my son turn over the engine (which was of course after I made this post)
Anyway, ordered my hose and tool from bob at dieselorings (for about $100 less than the stealership) and should be here thursday.
Good deal. At least you found it!
