to adjust my waste gate so it won't open to soon do you lengthen rod or shorten it
camdawag
camdawag
[/ QUOTE ]pull the red tube off. that will let u gain a couple more pounds.
do I needt to take the clip off of the rod to adjust? If so whats the best way to get the clip off?
yup, I have discovered that if you can get a piece of fishin string and tie it to the loop, you can bring it right back to you when it goes flying. anther option is to run down to NAPA and buy their 1/4" clip, someone may chime in with the part #. when you get the clip off you can just use a pair of vise grips to hold the rod steady while you use a small screw driver to turn it. It you have to bring it in a lot you may have to take it off and re-tap the threads to get rid of the dimple. I screwed mine in just enough to where I had to pull the rod out of the canister about 1/4-3/8" to connect it back to the waste gate, it should be under tension. I also used loc-tight on the threads just for reassurance.
More easily controllable wastegate idea. Machined a hole in the 1.15 BB turbine housing and welded in a V-band flange to mate the Tial Wastegate to the housing. Seems to work fine.
Wastegate
Kilo
