1 - 8 of 8 Posts
How much tension should the wastegate have the flapper vavle? Now i can pull it open very easily, this doesn't sound right to me? Any input? /ubbthreads/images/graemlins/shrug.gif
· Banned
Describe 'flapper valve'. The Wastegate is a small circular valve INSIDE the turbo, the EBPV is the large flapper valve at the exhaust where the downpipe bolts on.
The wastegate should be stiff to pull out. The EBPV will be easy to move without the rod connected.
which are you talking about?
Greg...the circular shaped wastegate is a flapper valve.
Hammer
· Banned
Hammer
...and? I just didn't want to miscommunicate on the terminology, seems a lot of folks mix up ebpv and wastegate, might be me though.
Just wanted to confirm what he was talking about.
Hammer
And the EBPV is a butterfly valve.
Hammer
Wastegate accuator, i gutted the ebpv, when i removed the turbo off of my truck the wastegate rod had very little tension on it, this didn't seem right to me? /ubbthreads/images/graemlins/confused.gif
· Banned
You may want to consider replacing it with a Banks Big Head Actuator
1 - 8 of 8 Posts
