Stroke fanatics, here's one for you. I purchased a 2001 7.3PSD in Sept of 01. Since then, this truck has run like a caddy up until now. A couple days ago my water in fuel light went on. Do you guys have any suggestions??????
Robert
Start simple, drain the fuel bowl and look for water. Or, drain the fuel bowl and change the filter. Might be just an accumulation of water in the fuel bowl, or if you don't have a pre-pump filter with water seperator, a good deal of water in the tank. First clear up the fuel bowl. Good luck 106
