On my last trip i was getting water in fuel lights. Stopped and drained the separator. I got about a 1/4 teaspoon of water and what looked like rust scale. Got the light again and had a mechanic drain it. He did into an oil drain pan so I have no idea what came. out. Got it again and I drained it. very little water but still to rust scale. I gave it an extra shot of Stanadyne and continued. The light came on again but went out shortly thereafter.
My question is what was that rust scale like matter I saw in the fuel. I did not touch it so I can not say for sure it it was in fact rust or algye.
I am home now and will drain the separator but could use some ideas as to what to look for.
The truck does sit for weeks at a time.
I can't help you as to where the rust is coming from, but when I had the persistent water light I cleaned out the water separator with brake cleaning fluid which cleaned out the flakes residing in the unit. I suspect there was some trash blocking/covering the sensor
How did you stop the fuel flow to have the separator clear to use the brake cleaner. I assume you allowed the brake cleaner to evaporate before replacing the plug.
