I have the Snow kit and use a 8 gallon tank in the tool box. System works ok for towing, I WOULD NOT RISK ruining my motor for a few extra horses by running a high meathanol mix, I run a 1 to 1 ratio ( 1 gallon of washer fluid to 1 gallon of water) it does cool the truck down, but the problem is it really is only effective on long grades, short (read) drag applications would not be beneficial to you. I am into my system about $1000.00 and unless you tow a lot look elsewhere. just my 2 cents..
I disagree man. I have heard of a good HP increases from water meth. I would think that 30% would add somewhere of 40RWHP and more importantly keep egt's in check. I can't remember, but isn't that the posters original intent?
On edit. If you want alot more power add nitrous. I am not totally sure what is will do to EGT's
if you want a small power increase and to keep your egt's in check I would go snowperformance water meth.
