I got my kit installed today and it works great. I am at 6000ft and I took it for a run up the mountian (10,000 +) and wow it ran cool. I normally get a lot of heat on that cruise but this help alot. I used stright water because i didn't have a chance to go pick some washer fluid or anything like that. Over all the kit took me 5 hours to install but I am 19 and it was the first big thing i have done to this truck as far as this indepth. It was the Snow Performance kit and the hardest part by far was taping the holes for the injectors ( I really suck at that for some reason). My question for yo guys is where do most of your mount your pump and tank I did it in a pretty odd place but it worked out great for me. Also how much easier is it to install it with the H2e pipes instead of the stockers. Thanks for any help.
Mine only took about 2 hours. I put the pump behind the air cleaner box, on the firewall and the controller and resivor on the side or the air box. It was a Tight fit and I alos have tha AFE intake.
But Iam going thru the 2qts of water in less than 20 miles. So Iam going to build a stainless steel 12 gallon tank to fit between the bed and frame.
Iam glad you saw a lower egts Mine might of lowered them 50 degs, but I still get to 1300 taking off. /ubbthreads/images/graemlins/frown.gif
