gents, recently i noticed coolant leakage. seems to be coming from underneath water pump but hard to see. it also seems to be intermittent. happens sometimes but not always and seem to be coming more times than not. while watching belt system it looks like water pump pulleys are loose. i read a water pump going bad can leak from the weep hole. does this sound like the problem to you guys? also, i noticed today that the voltage meter was reading low (like just past the 8 on the gauge). it didnt look like the belt was slipping but is it possible these issues could be related? thanks
