1 - 8 of 8 Posts
90,000 miles on motor and truck it is a 2002 psd has a chip in it and i have to put more coolant or water in it ever month or so had to stop near a pond and put 6 gallons in it with 2 24 oz cups because it was overheating and steaming it bubles water out of one of the connections when it gets hot and you can hear the coolant cap makinfg noise.i dont know what it is some say water poump but not sure. it does make some wierd squeeking noises so if any one has any information it will be greatly appreciated.
sounds like the water pump to me! Mine went out a few months ago with 108K on the truck. It never actually strted losing coolant through the weap hole. It just made a horrible grinding noise that got worse and worse. I popped the hood to find that while the truck was running, the water pump pulley looked like it was about to fly off it had soo much play in it!!!
Start by looking at it while its running. You can also squeeze the upper hose to see if its hot / circulating coolant!!
Muddin
hope this helps: link
redrocket
Redrocket-
Your link doesn't work. /ubbthreads/images/graemlins/shrug.gif
Pappy
Don't torque the water pump bolts to 36-45 like the article says. That is a misprint. 18ft/lbs is what it should say. Too many people on this site have stretched and broken off bolts due to the misprint. My 02 service manual says 18.
Maybe we could get one of the moderators to edit that procedure to correct the torque values?
Andy
yeah, I broke off a bolt(not because of the article), and it was a royal pain in the butt
redrocket
1 - 8 of 8 Posts
