If you have done any other V8 water pump, pretty much the same amount of time,, You can get the tool (Free loaner from AutoZone, or someplace similar.) to remove the fan from the pump. I have a different method that works fine,,, but some dissaprove of it! (My experience level, took maybe 2hrs,, including a good coolant flush) Since I was about 130k miles, and a little overdue for a coolant change anyway /ubbthreads/images/graemlins/phoney.gif) I went with the Fleetrite ELC NO Silicate AF and a
DIESELSITE Coolant filter.
If your upper hose routes through the serp belt. Change it to the "Preferred" Hose, (O'Rileys description on their 'puter /ubbthreads/images/graemlins/grin.gif but appropriate) It is the "Dual alternator" upper hose, and routes behind the belt into the nifty "Cradle" that LOOKS LIKE IT IS SUPPOSED to be there,,, /ubbthreads/images/graemlins/rolleyes.gif /ubbthreads/images/graemlins/phoney.gif DUH,, What in hell was FORD thinking? Why use the same upper alt bracket,, and a different hose??? ENGINEERS ARE SUCH IDIOTS sometimes,, (Flame suit on!)
