Heading home from dinner....
Drain water from fuel light came in earlier
Lost cruise.....
Pulled into rest stop....
Turned pitcock for water seperator....
Left it drain...
Could not remeber if you leave it drain...so left it open....
Got two miles up the road. ..dies on the road
Cranks and nothing...well now a dead battery!
Where do i start
Personally, I have no faith in the water in fuel sensor, located on the side of the water separator housing. Those messages usually mean paraffin build up or bad sensor. Don't know that I've ever seen anybody post that draining the water separator actually fixed anything once the message displayed on the dash. Instead, I see them fixing the sensor or cleaning out the housing.
But seriously, you left the drain open?
The correct procedure is to open drain, drain off a pint or so, CLOSE THE PETCOCK DRAIN and then remove air from fuel line by cycling the key 6 times.
Cycle the key = turn key on but don't start engine, wait 30 seconds, turn the key off
Start by shutting the water separator petcock. Then recharge your batteries. Then hope you can get the air out by doing the "cycle the key" sequence 6 times. If you still can't start it you'll need to move up to the fuel cooler and remove air there. You can search for a youtube video on how to do this.
I've never cycled the key after the drain process. I just run out a pint of so and close the valve. Never had any problems starting afterward. Never found even a drop of water, either.
Solved!!!!!!!!!!!!
Yes it was a stupid mistake, but was excited at midnight when it started running right - threw the hood down and away I went! - well for a mile or so!!! lol!
Changed both filters - lower filter was black, and i assume that drained the water cause it is not lighting up any longer??????
Put a battery charger on one battery and my sons truck on the other battery
cycled the key and attempted to start the truck for about an hour giving the truck a breather every 3 -4 attempts
Eventually it did start
