My 2012 6.7 Super Duty diesel has 20" Cast Aluminum Wheels; the spare is 18". I finally decided to order a 20" wheel to match the other 4 and the listed weight on the back is 3250 pounds. I have scoured the backs of the OEM wheels but cannot find the weight limit. Does anyone know the weight limit?
· Administrator
The wheel weight limit is likely higher than the weight limit of any tire that gets mounted to it. I don't think it's a concern.
Hi kl, my original tires were 275/20's with a max weight limit of 3750. Those 2, rear, tires would carry about 7500 pounds, so from the factory, I assumed that the wheels would have to support the same load as the tire. I upgraded those to 295/20's with a max limit of about 4100 pounds just for a larger tire. The scale weight of my truck with 5th wheel is a little over 7000 pounds; dry wt is about 3700. So the tires and wheels are well within safety limits. But, with this new wheel, with a weight limit of 3250, seems unsafe. That's why I'm curious. If the OEM's have the same rating, I guess that I have nothing to worry about.
