Late 1999 F250SD 7.3l
I was having a power steering leak, I proceeded to change the pump and then changed the steering gear box. In the mist of this I was on vacation and started hearing a grind or wine from front driver side. Narrowed it down to some known problems as in the wheel bearings or the needle bearing.
I needed to wait till pay day to get these parts and genuinely the weekend to get in and check some stuff out around the axle so I decided to lock my guns but stay in 2wd to see if that helps the noise. Well it made it worse actually so I switched it back to unlocked and now the noise is completely gone....
Anyone have any
