Where is the drain for the condensation to drain from the cab side of the a/c system.
My floor mats seem to have some water on them coming from underneath the dash. It is NOT antifreeze.
I must have a drain hole stopped up somewhere.
Thanks in advance for your response.
Jay
You could also have a poorly sealed windshield. Its a known problem on some trucks, and sometimes it affects the GEM and all sorts of electrical weirdness happens. Just a thought.
Roger
I had this a month or so ago when the humidity got up pretty high. It did it on one long trip and since it has dried up, no longer there.
I would check the condensate drain underneath the AC condenser (when I get off my fat, lazy butt). You may be able to insert a wire up into the drain from the outside and remove some gunk that may be in there. I think the drain is on the passenger side only. I did not have anything dripping from the driver's side.
