<font color="darkblue">
So are this:</font>
In tank: Modification of the stock mixing valve, usually removing it altogether and extending the return line so it won't churn the fuel being sucked in to the suction line.
And this:</font>
The filler line extends into the tank about 5" on the pickup leaving a big bubble at the top- like 5 gallons. On the excursion it's only a couple inches and not worth dropping the tank for. The mod is to simply cut it off as flush with the inside of the top as you can.
The same mods? Are they both called the In-Tank mods? Do I have to drop the tank? How does the filler line mod eliminate air from the system?
As for this one, mine usually doesn't have a problem.
</font>
Gutting the filler neck for accomodating the larger diameter "big rig" fuel nozzle is common. That means removing the flapper inside which is designed as part of the roll over protection. I suggest using a fuel cap.
Any pics or anything on how to do this, where to get the lines?</font>
The fuel suction line from the top of the tank to the fuel pump has a quick release fitting that is designed for pressure, not suction, and it leaks air into the fuel. Contributes to cackle and poor performance. cut it out and replace it with good diesel rated fuel line. The return side isn't a problem.
For this one I would need a kit like from Dennis at ITP, correct? Is there a wa to do the kit myself?</font>
Regulated fuel mod: instead of having the fuel pressure controlled by the factory regulator built into the fuel bowl, AND instead of having the fuel dead end in the heads, a Aeromotive type adjustable bypass regulator is used and the fuel system is replumbed to eliminate the fuel dead ending in the heads where air bubbles accumulate. Lots of variations on this mod, but they all accomplish basically what I've stated.
I'm very interested in the $50 version of this, where did you learn of this?</font>
FASS and AIRDOG are similar products that remove entrained air from the fuel. I've never had one but I have never heard of anyone badmouthing one after buying and installing one. I'm not aware of any other similar product on the market, however it is apparently possible to build something that will accomplish the same thing for around $50, so I've heard...but not seen.
Ok, just a couple more, why do I need one of these?
http://www.itpdiesel.com/store.php?crn=152&rn=407&action=show_detail
and which one of these is the Hutch mod, Harpoon mod etc?
