to use my obd-2 psd files go to
www.obd-2.com and click download and download Everything: Browser and all below optional files as a self extract full install package 95, 98, NT, 2K, BOB, ME, XP, LH or 3, 3.1, Workgroup. the downloaded file will create a car code file on your c: drive that will have all the bin files and the obd-2.exe file. open the obd-2.exe file and the program should start.
go here
http://webpages.charter.net/donjuane237/ and save koer1.dat and .log and psdparameter.dat and .log to the car code/sample folder. click on file/open in obd-2 software and the koer1.log and psdparameter.log files will be in the open file window. chose koer1.log and click ok. once you click ok on the file a message will pop up saying no comment file exists (click ok) and another one that says no vehicle info here (click ok). a set player fps box will appear above the vehicle explorer window that has back, stop, and play options. click play and my koer test will play back for you. to see test results click the test icon in vehicle explorer then click enhanced (above and to the left). this will bring up the enhanced test screen. the results of the cylinder contribution and switch test will be listed.
if you want to see all the parameters available for our psd click end (above the status icon). click file/open and chose the psdparameter.log, click play on the player, then click the data icon in vehicle explorer then enhanced. it takes about 75 seconds, (less if you adjust the playback to 300%), before all parameters are uploaded and start updating. once they are all there you can click on them individually to get a description of the parameter. this is free and available to anyone. it should take about 15 minutes to run through the entire process. i will check back periodically so post any problems that occur. hope this will help out.
