Howdy, been in hospital a few times, wife abandoned child and I so now trying to get things going.
My 1988 F350 7.3L idi, CC had not been started in two years. I had seen a leak at right front injector cap so I ordered the injector return line kit from a member here. I had a large solar battery maintainer connected to the batteries. I added about 8 gallons a fuel to front tank but no start. So i was able to get it started by filling fuel filter with Amsoil's diesel rescue solution then poured the rest into the front tank. Friend came over while it was running, I turned it off and it started up just fine, we drove it down the road and back for a test without issue. Then took it to a mechanic to have return line kit installed and radiator boiled. After kit was installed it wouldn't start all day of trying at all my friend told me. So I drove to the shop. The mechanic was still trying to start it, spraying ether down it, then cranking until the engine was too slow, hooked up commercial battery charger and kept repeating. I felt the battery and it was hot. More ether was sprayed again and again until I couldn't breath (I'm on oxygen). Then I noticed the second IP wire was not connected. Once connected it started up. Then all the fuel was being transfered to rear tank and over flowing. So fuse was getting blown for tank divertor so it had to be replaced. Also batteries not holding up and alternator bad and mechanical fuel pump went bad. All this happened at the sane time. So, is this all a coincidence?
Thanks, JASTECH
Thanks, JASTECH
