I have decided that I am going to pull the turbo off my truck and check and clan the ring. The truck is a 2005 F350. What all do I need to get this job done? I have the tools, but what will I want to have on hand as far as gaskets or seals?
As I posted in a previous thread a few weeks ago the turbo is over boosting. Every time it does I get 3 codes, P0234 P0460 and P0463. I am also getting a faint smell of oil after long trips. I looked and can see a slight oil leak on a tube that comes off the front of the turbo. It is a small metal tube on the bottom side of the turbo. It looks like there is a very small amount of oil dripping from the turbo side of this tube.
So, what all will I want to have on hand when I take the turbo off?
Turbo install kit from Ford has all the o-rings and gaskets, plus new bolts. For cleaning you can just use an air angle grinder with a gasket cleaning pad, and add a very light coat of antiseize on reassembly.
You can cut 1" cleaning pads down to 1/2" with scissors and hold the backing pad against a grinding wheel while running the die grinder to cut it down to size. Harbor Freight or Northern has cheap angle grinders.
I don't know about those, but when I rebuilt mine at @ 140,000 there was no corrosion to speak of, and I live by the Chesapeake Bay. Mine is a daily driver though. It seems that those that sit have more corrosion problems. I did replace my unison ring with a Ford one off of Ebay.
My truck came from Daytona Beach Fla, i'm guessing thats where the corrosion came from
Some of the byproducts of combustion are corrosive. Geographical location probably has little to do with it.
