1 - 8 of 8 Posts
What all do I need to get into the 14's? I know each truck is different, but mine seems stronger than other 7.3s i've driven. Ive got intake and exhaust so far...so basically stock. I've been told with a hot chip and intake/exhaust its possible to hit 14.9's, that true?
Thanks for any input.
HouTex /ubbthreads/images/graemlins/smokin.gif
My numbers come from my Edge Evo Programmer, not from the dragstrip, so take them for what your will. Given the "lower level" of mods I have ( the Edge Evo is not even on Extreme) they seem pretty strong. I think the key is both a nice, easily broken in motor before mods and the stock tire and wheel size (see sig).
I cant wait until 104k when the warranty expire so I can put a chip (tiption), a WW,etc and see what she'll really do!!!!!
Given that our trucks are almost identical in size and weight (mine weighed in a 6,290 with a 1/4 tank) you should be able to get into the 14.9 range with an Edge Evolution programmer along with your intake and exhaust. I've only done about 3 - 1/4 mile runs and 15.14 is my best so far, and that was with a mediocre launch and the Evo set on the middle level. I've heard that tire size can affect performance quite a bit, the more mass to rotate, the slower the acceleration. I am running stock size tires on factory aluminum wheels. If you dont have any warranty issues (mine runs out at 104k) then maybe a flip chip is the your answer. If you still have a warranty, then the Edge Evo is tough to beat for performance and drivability.
Good luck with your decision.
look at my sig, My best is 15.4 I have a 4x4 lariat. hope this helps
I prolly could be in the 14s if I got a true piggyback tuner, custom programming. wish i had done that in the first place. I here good things about jodys stuff on here. Also being a 4x4 adds time to my time.
· Banned
if you had custom tuning there would be no need for stacking other crap with your chip. 4x4 should help your 1/4 times out, why do you think we all launch and run in 4x4?
1 - 8 of 8 Posts
