21 - 26 of 26 Posts
Does anyone got a picture of this while on the motor? I am told and gratful that its on the back of the HPOP but not sure if I am seeing it right... Is it off to the drivers side of the HPOP down low?
yes and it is and has 2 wire connector that leads up and around the fuel filter and attaches there with a clip for support.
1/2 Fine thread. I shortened the spacer on a lathe and then used a thin nyloc nut. Permanent fix! Be sure not to over tighten or IPR could malfunction it stretched. Also if you use too much loctite removing the nut could twist the very thin tube in the IPR. Then it will stick.
21 - 26 of 26 Posts
