1 - 10 of 10 Posts
What is it and what does ICP stand for?
I'm trying to look it up on ALL DATA PRO.
Injector control pressure sensor.
the icp is on the hpop cover under your turbo. its on the driver side of the cover. You can look at it if you pull your intake.
Actually since its an 2006 it will be on the passenger side valve cover.
I think only the 03s and some early 04s had it under the turbo.
What happens if that goes out?
When mine went out it ran kinda rough, and started hard when it was cold, but it really ran the same as before once warm. I drove it for about a month before I finally replaced it.
JD, when mine went out, my truck would surge occasionally. But the worst is, while sitting at a red light, the truck would surge hard and try to push me out into the intersection if you didn't keep foot on the brake! It never coded, ford couldn't find out what was wrong, they kept it for a week! I call my company fleet manager and explained what would cause this and he said the company quit sending the trucks to ford and just changed the ICP sensor themself because they couldn't wait a week for the truck. Ford finaly changed mine when i said that if it pushed me into the entersection and i wrecked with someone they could get ready! The dealer immediately changed it! Good luck.
Discussion Starter #8
My truck is sputtering at WOT. So, I was thinking that the injectors were not firing correctly.
Discussion Starter #10
1 - 10 of 10 Posts
