I need to replace the black rubber as you can see. Just trying to look up the part online or at least pick one up at NAPA or Ford?
thanks
Hi, that is the waste gate solenoid.
You need the plastic pressure line set. The red and green plastic lines are an assembly. The red goes back to the waste gate actuator on back of turbo and the green plugs into side of air intake hose.
Pretty sure you will need it from ford or International
Autonation Great Bear Lake is a vendor that sells for 10 percent over but I think it's around $20 o begin with.
