Well i just studied the solenoid operation and the 4r100/E4OD both need solenoid 1 engaged for manual 1 . My problem was solenoid 1 was not engaging in man1 when checked with a meter. However I was getting the .7 volts from the mlps in manual1position. I swapped the PCM out now Manual 1 works great. This tells me that an unplugged solenoid connector will not let the transmission work/ in manual like everyone thinks,ss1 needs 12 volt for man1 . unplugged , the solenoids are both off and is equivalent to man 2... So, in Manual one unplugged , this transmission will combine 1 and 2 clutches and drag.
However, now I have weak reverse just like the problem with the 4r100 pcm plugged in. This also tells me i have an epc problem in reverse ..
