I have two questions for you folks this evening.
1) What kind of axles are under my truck assuming that it is completely stock and has 4.10 gears and LS in the rear?
2) Can anyone give an educated guess on what the curb weight is on my truck stock? Maybe specify if that is full of fuel or empty (I assume some guesses are from the scales).
Truck is in the sig, thanks.
Also, I'm not sure if I put it in the sig, but my truck is an XLT.
· Super Moderator
You have a Dana 60 in the front and a Ford Sterling 10.25 in the rear and I would guess your curb weight to be around 6,000 lbs. For the life of me I can't remember what mine weighed in the last time that I took a dump run.
Your going to be between 7000# & 7200# full of fuel with just a driver and an empty box.
As noted in my signature and with contractor cap and tools (@800 lbs), full of fuel and me on board (300 lbs) my 95 F250 2 wheel drive extended cab long bed weights are: steer 3620, drive 3860 total 7480.
