I have an 08 f250 that im looking to lift but im not sure what i should do. I dont want anything wild i just want a more aggressive stance. I have 22x10 rims with a -21 backspacing that i am looking to put on 35 inch tires. Im not sure if they will fit without serious rubbing on just a 2 inch leveling kit. What I had in mind was the bds 2 inch level kit with all new bilsteins and 5 blocks in the back getting rid of the 2 inch stock ones. This should make the truck sit about level because right now it sits about an inch higher in the front. Do you think these wheels and tires would fit with the leveling kit or should I save up the extra money and go with the bds 4 inch lift?
I just installed an Icon Vehicle Dynamics 2.5" lift, with the Icon TEI 1" coil spacer for a total of 3.5" in the front and I think it looks :thumbsup:. It had the saggy diaper look in the rear which some like, but I don't so I put a 5" block from Icon in the rear, and now it roughly sits about 1.5" higher in the rear and looks great. It sets it apart, but it's not huge....I have some 35's on order and see no problems with them clearing....I think the Icon stuff is pretty top notch, worth checking them out!
I just put a procomp 8" lift on my 08 F350.
The stock 08 F350 should accomodate a 33" tire without modification as the original tires (at least mine) were about 33 inches so you should only have to go a ccouple of inches (4" max) for 35" tires.
Here are a couple of pictures...
Before the Lift
After the Lift
