I am having an Eaton Posi installed (to replace my POS Factory Limited Slip), and I have a question about the lube that should be used.
As y'all know, the Form owners manual says to use a 75W-140 Synthetic oil.
The printed materials that come with the Eaton state that a "mineral based 80W-90 oil" should be used. They also state that "Use of synthetic lube is not recommended".
I'm not a rear end expert, but I thought that the purpose of the lube was to protect the ring and pinion gears and bearings; with that in mind, I was thinking that a different lube (i.e. not 75W-140) might result in damage to the gears.
I am curious as to what other Eaton Posi owners are using...
Thanks,
Thanks,
