hey all again, just to recap, I know I should put it in my signature, but anyway, 1992 7.3, with ats turbo, and 3" exhaust, and a 5 speed and 4.11 gears, I live in colorado so anywhere i go there are hills, now for the scenario
take off from a light, get on the truck pretty hard, black smoke at first(normal I assume) but I can only achieve 8 psi no matter how hard i try, and this doesn't happen till like 2500 rpm or more, in fact at 2000 rpm, I get no boost, even when cruising and I jump on the gas at 2000 I get no boost, all that happens is more black smoke and my pm shoots through the roof, unloaded in town, I can hit 1000-1100 if I want, and I am not even really going all that fast, I feel as if the turbo isn't really working all that well
scenario 2) total maybe 5000 extra #'s slight hill maybe 5% or so, and in order to keep a steady speed of 40 or 65 or whatever you obviously need to give a little more gas, now once again the pm shoots up there in about no time and I have to back of the gas, thus slowing me down and thus defeating the purpose of a turbo diesel
to sum it up, pm are really high I think, maybe this is normal, but it seems that is the last concern of other people, and low boost I think again, not sure this is the only idi I have ever been in, maybe this is normal, if so, i am very un satisfied with the ole idi setup
is all the black smoke extra fuel, I mean is the pump turned up too much or something or what is the deal?
tanks in advance
Dustin
Black smoke is unburned fuel. You should have a little bit when you lay down hard on it...
Yeah, Ive always heard the complaints of not getting good enough boost soon enough...
If you tow often, i really dont know what to do. If not, Id turn it up to 12 psi max.
someone else will be of better help
Sounds like your turbo's wastegate is stuck open, or possibly a bad turbo.
Your problem isn't the fuel, but that the turbo isn't boosting, so that you are in effect overfueling since you don't have the extra air.
How long has it been since you changed or cleaned the air filter?
