I just drove down from Kingman, AZ (Where I live - "close to retirement") to San Diego, CA (Where I am stationed), In my 96 F350 7.3L 210000miles....
At the ThousandPalms "Flying J" I checked the oil and it looked low and wierd - but I couldnt recognize the smell (seemed to be a combo of stuff).. It was NOT chocolate milk looking as if it was pure antifreeze.. but it did have some bubbles and was a runny... So I dumped in 3 bottles of LUCAS engine oil additive (to thicken up the mix) to get me the remaining 138miles to base so I could get underway yesterday morning (didnt wanna miss ships movement).. I didnt have the time Monday morning when I got in to check everything very thorough due to the time and it was dark out (0330). but it almost smelled like diesel and antifreeze.. like I said a wierd smell.. the exhaust had ZERO smoke of any kind.. but did smell of oil.
(Usually a 6hr trip - ended up being a 10hr trip, cause I wanted to take an easy).. ..
So I have came to the conclusion of (All base on Internet Searching):
- Possible blown head gasket
- I need to pressure test my coolant system
- Probably will have to replace the injector cups (will know forsure when I remove the injectors)
- should probably replace the injector O-rings (Speaking of this - Anyone have the numbhers for the injector O-Rings from VITON)
- Need to check the coolant overflow for oil slick.
Is there anything else I need to look at?? I did atleast mark the coolant overflow bottle so after this week of underway I can see if there is a difference.. and as far as fuel.. well all I could do is mark where the needle was at when I turned it off.
Thanks for any assistance and or insight..
Tim
also check your fuel filter for oil contamination, if the filter is black... it usually means injector orings are shot.
Could be your engine oil cooler.
I just did mine. Different sympton though, I had an oil leak coming out of the oil cooler o-ring.
But oil AND coolant come together at the oil cooler.
Just a thought.
