The rubber boots are falling apart due to years of oil exposure. I'm replacing the wastegate actuator and while inspecting the old one I noticed both the red and green tubes had popped out.
They had only been inserted for a single test drive after I replaced all 6 boots before popping out.
Anyone know what the official part name and number is for the full harness?
Alternate to replacing them, the site I purchased the wastegate from says I can simply delete all 3 red and green lines and plug the holes.
Is there any drawback to this? If nothing major, what's recommended for plugging the holes?
Here is the part number f81z9e498da, eBay has them around 17.00 to 20.00.
OEM F81Z-9E498-DA Main Emissions Vacuum Line Harness Assembly for Ford 7.3L
Awesome thanks. I wasn't having any luck describing the part in Google.
You will want them installed
Thanks, I've ordered a set. BTW, thanks to all those who provided information about diagnosing air leaks and replacing the boots. With the boots replaced (and soon the wastegate actuator) I'm getting boost again.
