Backstory: Father-in-law purchased a 1999.5, F-350, 7.3L in 2015. He purchased it in the summer and uses it mainly to tow his giant fifth wheel all over God's green earth but sometimes he uses it to for his daily driver, especially in the winter. The winter of the year he bought it he noticed in order to start it in anything under 40°F he had to cycle the key through the GP indicator light cycles three or more times. Assuming the problem was just thick oil and the engine being extremely cold-blooded he decided that this wasn't an issue and lived with it. Fast forward to 2018 on a very snowy crap of a day, he jumped into it after work and the thing wouldn't start no matter how much he cycled the key until he finally killed the battery. He plugged the heating system into a jump box for an hour and jumped the battery with another truck and was finally able to get it home, needless to say, by the time he was done he was extremely frustrated. Up to that point he'd never had to plug it in, since then he has plugged the heating system in every time the temp gets below 50° F but the hard start has gotten progressively worse and now he will not take it somewhere he can't plug it in after sitting for 30 minutes or more. Also, he is now required to cycle the key three-plus times any time he starts it under 40° F no matter when the last time it ran, 10 seconds or 30 days.
Forward to fall 2020 and it is sitting in my driveway as I am trying to replace the dreaded sloppy steering gearbox. It's about 37°F outside, not knowing about the cold start issue I attempted to start it and it wouldn't. After getting the backstory from him I decided to look into it and have gone down a three-month-long rabbit hole with this thing. I've rebuilt the HPOP, IPR, changed the oil lines, changed the glow plugs, GPR, and purchased an AutoEnginuity scanner from RiffRaff.
I NEED HELP! I am still having the issue, I recorded the Engine RPM, ICP pressure (PSI), ICP (Duty Cycle), ICP (Voltage), Vehicle Speed, and for ****s and giggles the Coolant temp data from an interstate drive and would like to have someone that knows what the heck they are looking at take a look at it.
Idle
ICP Avg = 511 psi
Duty Cycle Avg = 13.83%
Cruise 60-80 MPH
ICP Avg = 1819 psi
Duty Cycle Avg = 29.12%
ICP Range = 415.75 - 2746.78 psi
Duty Cycle Range = 10.94 - 40.62%
Please let me know if you want the report.
Any assistance would be greatly appreciated as I am at my wit's end with this thing!
Idle
ICP Avg = 511 psi
Cruise 60-80 MPH
ICP Avg = 1819 psi
